Zum Hauptinhalt wechseln
Hamilton Beach 51101BA Motor Replacement
Was du brauchst
  1. Hamilton Beach 51101BA Motor Replacement, Rotor: Schritt 1, Bild 1 von 3 Hamilton Beach 51101BA Motor Replacement, Rotor: Schritt 1, Bild 2 von 3 Hamilton Beach 51101BA Motor Replacement, Rotor: Schritt 1, Bild 3 von 3
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Motor Replacement: Schritt 2, Bild 1 von 1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Motor Replacement: Schritt 3, Bild 1 von 1
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
  4. Hamilton Beach 51101BA Motor Replacement: Schritt 4, Bild 1 von 1
    • Unhinge the plastic motor platform from the blender.
    • You may need a plastic spudger to unhinge the motor platform from the blender.
  5. Hamilton Beach 51101BA Motor Replacement: Schritt 5, Bild 1 von 2 Hamilton Beach 51101BA Motor Replacement: Schritt 5, Bild 2 von 2
    • Using a spudger, carefully insert the tip into the coil of wire around motor.
    • This is used to hold the rotating piece of the motor still.
  6. Hamilton Beach 51101BA Motor Replacement: Schritt 6, Bild 1 von 1
    • Remove the white rotor piece by rotating it counter-clockwise.
    • While rotating, make sure the rotating piece of the motor remains still.
  7. Hamilton Beach 51101BA Motor Replacement, Motor: Schritt 7, Bild 1 von 2 Hamilton Beach 51101BA Motor Replacement, Motor: Schritt 7, Bild 2 von 2
    • Move the motor platform to the side.
    • Lift up the motor and remove it from the blender.
  8. Hamilton Beach 51101BA Motor Replacement: Schritt 8, Bild 1 von 1
    • Some soldering experience required!
    • Desolder the red wire from the green plastic piece.
  9. Hamilton Beach 51101BA Motor Replacement: Schritt 9, Bild 1 von 1
    • Cut the thin black wire from the wire cap.
Abschluss
Andrew Huff
568 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 2-5, Sullivan Fall 2015 Mitglied von USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
This article appears to be unfinished. You cut 2 wires at the end... then what? Reconnecting them doesn't make any sense.
Geo Jack Jack - Antwort
Que tipo de motor tengo que comprar?
hugoalex521 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 66
Insgesamt: 6,789
