Einleitung
After using this guide you will have learned how to replace the power button to your blender. You will need to use basic tools and soldering to complete this guide.
Was du brauchst
Remove the container from the base.
Hold the blender and the container, then twist the container in a clockwise motion.
Turn the blender so the bottom is facing you.
Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
On the back of the power button, desolder the red and grey wires that are connected to the piece.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
