Einleitung
In this guide you are going to learn how to take out the current power cord in order to replace it with a new one.
Was du brauchst
Remove container from base.
Hold the blender and the container, then twist the container in a clockwise motion.
Turn the blender so the bottom is facing you.
Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
To reassemble your device, you must solder the new power cord to the thin black and thin gray wires, and follow the steps in reverse order. Requires soldering skills.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
