Einleitung
After using this guide you will have learned how to replace the rotor to your blender. You will need to use basic tools to complete this guide.
Was du brauchst
Remove the container from the blender.
Hold the blender and the container, then twist the container in a clockwise motion.
Turn the blender so the bottom is facing you.
Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
