Einleitung
This page will guide you through the replacement of the power cord on your Hamilton Beach Classic Stand Mixer 64650. This guide is helpful if you are experiencing any problems with turning on the mixer. If your device will not turn on despite all efforts, this is probably the best guide for you to follow!
Was du brauchst
Flip the handle on its side. Remove five 3.8 mm Philips #2 screws shown and set aside them aside.
Remove the four 8.6 mm Philips #2 screws securing the motor mount and place them aside.
Carefully pull the motor block out of the case.
Collect the two spring located on top of the white beater gears. The springs are held in place with compression, and may fall into the case when the motor is moved.
Remove the seven 5.6 mm Philips #2 screws that attach the motor casing to the mixer handle and set them aside.
Use a plastic opening tool to take off the handle's cap by loosening both ends and then sliding the tool to the middle of the handle.
Remove speed level from the inside of the case by applying light pressure toward you.
Remove the beater release button from speed level by removing the two 1.3 mm Philips #2 screws.
Replace the speed level assembly.
Liftback end of the handle up from motor casing.
Pull back to detach fully from the stainless steel.
Untie the black lead's knot.
Cut both wires with handheld wire cutters.
Follow this guide to solder new power cord wires in.
