Zum Hauptinhalt wechseln
Hamilton Beach 64650 Quick Burst Button Replacement
Was du brauchst
  1. Hamilton Beach 64650 Quick Burst Button Replacement, Motor: Schritt 1, Bild 1 von 3 Hamilton Beach 64650 Quick Burst Button Replacement, Motor: Schritt 1, Bild 2 von 3 Hamilton Beach 64650 Quick Burst Button Replacement, Motor: Schritt 1, Bild 3 von 3
    • Flip the handle on its side. Remove five 3.8 mm Philips #2 screws shown and set aside them aside.
  2. Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 2, Bild 1 von 3 Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 2, Bild 2 von 3 Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 8.6 mm Philips #2 screws securing the motor mount and place them aside.
  3. Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 3, Bild 1 von 3 Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 3, Bild 2 von 3 Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 3, Bild 3 von 3
    • Carefully pull the motor block out of the case.
    • Collect the two spring located on top of the white beater gears. The springs are held in place with compression, and may fall into the case when the motor is moved.
    • Handle the wires with care to ensure you do not break any of them.
  4. Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 4, Bild 1 von 3 Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 4, Bild 2 von 3 Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 4, Bild 3 von 3
    • Desolder the six wires connected to the motor using this guide.
    • Make sure to note colors when you disconnect them and remember where to reconnect them later.
  5. Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 5, Bild 1 von 2 Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 5, Bild 2 von 2
    • Once disconnected, the motor will slide out easily.
  6. Hamilton Beach 64650 Quick Burst Button Replacement, Quick Burst Button: Schritt 6, Bild 1 von 3 Hamilton Beach 64650 Quick Burst Button Replacement, Quick Burst Button: Schritt 6, Bild 2 von 3 Hamilton Beach 64650 Quick Burst Button Replacement, Quick Burst Button: Schritt 6, Bild 3 von 3
    • Remove the seven 1.3 mm Philips #2 screws that attach the motor casing to the mixer handle and set them aside.
  7. Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 7, Bild 1 von 3 Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 7, Bild 2 von 3 Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 7, Bild 3 von 3
    • Use a plastic opening tool to take off the handle's cap by loosening both ends and then sliding the tool to the middle of the handle.
  8. Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 8, Bild 1 von 2 Hamilton Beach 64650 Quick Burst Button Replacement: Schritt 8, Bild 2 von 2
    • Lift the handle cap upward once it is loose.
    • Be careful when you remove the handle cap as the quick burst button likes to fly away.
    • Replace the button assembly as needed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Gwen Davis
519 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 7-3, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 7-3, Catania Spring 2016
UMASSD-CATANIA-S16S7G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 580
