Einleitung
This page will guide you through the replacement of the speed level on your Hamilton Beach Classic Stand Mixer 64650. This guide is helpful if you are experiencing any problems with your speed level adjustment.
Was du brauchst
Flip the handle on its side. Remove five 3.8 mm Philips #2 screws shown and set aside them aside.
Remove the four 8.6 mm Philips #2 screws securing the motor mount and place them aside.
Carefully pull the motor block out of the case.
Collect the two spring located on top of the white beater gears. The springs are held in place with compression, and may fall into the case when the motor is moved.
Remove the seven 5.6 mm Philips #2 screws that attach the motor casing to the mixer handle and set them aside.
Use a plastic opening tool to take off the handle's cap by loosening both ends and then sliding the tool to the middle of the handle.
Remove speed level from the inside of the case by applying light pressure toward you.
Remove the beater release button from speed level by removing the two 1.3 mm Philips #2 screws.
Replace the speed level assembly.
