Einleitung
Removing the base of your food processor is necessary for additional repairs and cleaning.
Was du brauchst
Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
Use a spudger to remove the 4 rubber base pads located at the corners of the device.
Unscrew all 4 screws that are located beneath the pads with a screwdriver and remove the plastic grey base.
Eine weitere Person hat diese Anleitung absolviert.
