Einleitung
Replacing of processor base. Be sure the processor is unplugged before beginning.
Was du brauchst
Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
Pull suction cups straight out.
In diesem Schritt verwendetes Werkzeug:Heavy-Duty Spudger$4.99
Remove rubber caps using the heavy duty spudger.
Remove the four 11 mm screws using the #2 Phillips head screwdriver.
Pull base straight out.
Abschluss
