Einleitung
Replacement of the drive gears. Do not remove grease as it helps the gears move smoothly.
Was du brauchst
Using a #2 Phillips head screwdriver, remove the four 10 mm screws and pull the shaft straight upwards to uncover gears.
3 weitere Personen haben diese Anleitung absolviert.
