Zum Hauptinhalt wechseln
Hamilton Beach 70740 Internal switch Replacement
Was du brauchst
  1. Hamilton Beach 70740 Internal switch Replacement, Bowl and Lid: Schritt 1, Bild 1 von 2 Hamilton Beach 70740 Internal switch Replacement, Bowl and Lid: Schritt 1, Bild 2 von 2
    • Turn the bowl counterclockwise and lift.
  2. Hamilton Beach 70740 Internal switch Replacement, Power Knob: Schritt 2, Bild 1 von 3 Hamilton Beach 70740 Internal switch Replacement, Power Knob: Schritt 2, Bild 2 von 3 Hamilton Beach 70740 Internal switch Replacement, Power Knob: Schritt 2, Bild 3 von 3
    • Using the heavy duty spudger pry the plastic knob off the front of the processor.
  3. Hamilton Beach 70740 Internal switch Replacement, Base: Schritt 3, Bild 1 von 2 Hamilton Beach 70740 Internal switch Replacement, Base: Schritt 3, Bild 2 von 2
    • Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
    • Pull suction cups straight out.
  4. Hamilton Beach 70740 Internal switch Replacement: Schritt 4, Bild 1 von 3 Hamilton Beach 70740 Internal switch Replacement: Schritt 4, Bild 2 von 3 Hamilton Beach 70740 Internal switch Replacement: Schritt 4, Bild 3 von 3
    • Remove rubber caps using the heavy duty spudger.
    • Remove the four 11 mm screws using the #2 Phillips head screwdriver.
    • Pull base straight out.
  5. Hamilton Beach 70740 Internal switch Replacement, Internal switch: Schritt 5, Bild 1 von 2 Hamilton Beach 70740 Internal switch Replacement, Internal switch: Schritt 5, Bild 2 von 2
    • Remove the two 11 mm screws using the #2 Phillips head screwdriver.
  6. Hamilton Beach 70740 Internal switch Replacement: Schritt 6, Bild 1 von 2 Hamilton Beach 70740 Internal switch Replacement: Schritt 6, Bild 2 von 2
    • Cut all four red wires using the wire stripper crimping tool.
    • Using the wire stripper crimping tool strip the ends of each red wire and insert them into a new wiring connector cap, then crimp firmly.
    • Cut the white wire using the stripper crimping tool.
    • Using the wire stripper crimping tool strip the ends of each of the white wires and insert them into the opposite ends of a parallel connector, then crimp firmly.
Abschluss
USF Tampa, Team 17-4, Blackwell Spring 2017 Mitglied von USF Tampa, Team 17-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G4
3 Mitglieder
7 Anleitungen geschrieben
2 Kommentare
On our unit the control knob became stuck. Where can I get a new control knob? Do you happen to know the part number?
Mitchell Arends - Antwort
I used a hair dryer and that did the trick, but am wondering if WD 40 would work as well. I went online e with the company and they want $2.00 for tech advice which is dumb to me. At first I thought it was the locking device on top; it is actually the pulse switch and my machine is just over a year old.
joanneferrato - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 904
