Zum Hauptinhalt wechseln
Hamilton Beach 70740 Motor Replacement
Was du brauchst
  1. Hamilton Beach 70740 Motor Replacement, Bowl and Lid: Schritt 1, Bild 1 von 2 Hamilton Beach 70740 Motor Replacement, Bowl and Lid: Schritt 1, Bild 2 von 2
    • Turn the bowl counterclockwise and lift.
  2. Hamilton Beach 70740 Motor Replacement, Gears: Schritt 2, Bild 1 von 2 Hamilton Beach 70740 Motor Replacement, Gears: Schritt 2, Bild 2 von 2
    • Use the nylon spudger to remove the plastic screw covers.
  3. Hamilton Beach 70740 Motor Replacement: Schritt 3, Bild 1 von 3 Hamilton Beach 70740 Motor Replacement: Schritt 3, Bild 2 von 3 Hamilton Beach 70740 Motor Replacement: Schritt 3, Bild 3 von 3
    • Using a #2 Phillips head screwdriver, remove the four 10 mm screws and pull the shaft straight upwards to uncover gears.
  4. Hamilton Beach 70740 Motor Replacement: Schritt 4, Bild 1 von 2 Hamilton Beach 70740 Motor Replacement: Schritt 4, Bild 2 von 2
    • Firmly grasp center piece of gear mechanism and pull straight upward.
  5. Hamilton Beach 70740 Motor Replacement, Motor: Schritt 5, Bild 1 von 2 Hamilton Beach 70740 Motor Replacement, Motor: Schritt 5, Bild 2 von 2
    • Using a #2 Phillips head screwdriver, remove the two 11 mm screws and pull the rubber suction cups straight up.
  6. Hamilton Beach 70740 Motor Replacement: Schritt 6, Bild 1 von 3 Hamilton Beach 70740 Motor Replacement: Schritt 6, Bild 2 von 3 Hamilton Beach 70740 Motor Replacement: Schritt 6, Bild 3 von 3
    • Using the heavy duty plastic spudger remove the four rubber caps.
    • Using a #2 Phillips head screwdriver, remove the four 11 mm screws inside each of the bases legs.
    • Pull the base straight up to remove it from the processor.
  7. Hamilton Beach 70740 Motor Replacement: Schritt 7, Bild 1 von 3 Hamilton Beach 70740 Motor Replacement: Schritt 7, Bild 2 von 3 Hamilton Beach 70740 Motor Replacement: Schritt 7, Bild 3 von 3
    • Using a #2 Phillips head screwdriver, remove the four 9 mm screws.
    • From the open base pull the motor straight out.
  8. Hamilton Beach 70740 Motor Replacement: Schritt 8, Bild 1 von 2 Hamilton Beach 70740 Motor Replacement: Schritt 8, Bild 2 von 2
    • Using the wire stripper crimping tool cut the black wire connection from the power cord to the motor.
    • Using the wire stripper crimping tool strip the ends of each of the black cords and insert them into the opposite ends of a parallel connector, then crimp firmly.
    • Using the wire stripper crimping tool cut the four red wire connections from the switch to the motor and then rewire the four red wires together in a wiring connector cap.
    • Using the wire stripper crimping tool strip the ends of each red wire and insert them into a new wiring connector cap, then crimp firmly.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 17-4, Blackwell Spring 2017 Mitglied von USF Tampa, Team 17-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G4
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 3,014
