Zum Hauptinhalt wechseln
Hamilton Beach 70740 Power Cord Replacement
Was du brauchst
  1. Hamilton Beach 70740 Power Cord Replacement, Bowl and Lid: Schritt 1, Bild 1 von 2 Hamilton Beach 70740 Power Cord Replacement, Bowl and Lid: Schritt 1, Bild 2 von 2
    • Turn the bowl counterclockwise and lift.
  2. Hamilton Beach 70740 Power Cord Replacement, Base: Schritt 2, Bild 1 von 2 Hamilton Beach 70740 Power Cord Replacement, Base: Schritt 2, Bild 2 von 2
    • Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
    • Pull suction cups straight out.
  3. Hamilton Beach 70740 Power Cord Replacement: Schritt 3, Bild 1 von 3 Hamilton Beach 70740 Power Cord Replacement: Schritt 3, Bild 2 von 3 Hamilton Beach 70740 Power Cord Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Heavy-Duty Spudger
    • Remove rubber caps using the heavy duty spudger.
    • Remove the four 11 mm screws using the #2 Phillips head screwdriver.
    • Pull base straight out.
  4. Hamilton Beach 70740 Power Cord Replacement, Power Cord: Schritt 4, Bild 1 von 3 Hamilton Beach 70740 Power Cord Replacement, Power Cord: Schritt 4, Bild 2 von 3 Hamilton Beach 70740 Power Cord Replacement, Power Cord: Schritt 4, Bild 3 von 3
    • Using a #2 Phillips head screwdriver, remove the four 9 mm screws.
    • From the open base pull the motor straight out.
  5. Hamilton Beach 70740 Power Cord Replacement: Schritt 5, Bild 1 von 1
    • Using the wire stripper crimping tool cut the black wire connection from the power cord to the motor and then rewire the new power cord to the motor.
  6. Hamilton Beach 70740 Power Cord Replacement: Schritt 6, Bild 1 von 2 Hamilton Beach 70740 Power Cord Replacement: Schritt 6, Bild 2 von 2
    • Remove the two 12 mm screws using the #2 Phillips head screwdriver.
    • Remove plastic piece.
  7. Hamilton Beach 70740 Power Cord Replacement: Schritt 7, Bild 1 von 2 Hamilton Beach 70740 Power Cord Replacement: Schritt 7, Bild 2 von 2
    • Remove the three 12 mm screws using the #2 Phillips head screwdriver.
    • Remove the plastic piece by pulling straight up.
  8. Hamilton Beach 70740 Power Cord Replacement: Schritt 8, Bild 1 von 2 Hamilton Beach 70740 Power Cord Replacement: Schritt 8, Bild 2 von 2
    • Remove the power cord from the ground by removing the solder with the soldering tool.
    • Solder the new ground from the new power cord.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 17-4, Blackwell Spring 2017 Mitglied von USF Tampa, Team 17-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G4
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 996
