Einleitung
Use this guide to separate the back cover from the front.
Was du brauchst
Remove the outer screen cover by releasing the top clip from the main body of the device.
Remove the battery cover by releasing the clip from the main body of the device.
Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
