Zum Hauptinhalt wechseln
Handspring Visor Deluxe PDA Touch Screen Replacement
Was du brauchst
  1. Handspring Visor Deluxe PDA Touch Screen Replacement, Outside cover and stylus: Schritt 1, Bild 1 von 2 Handspring Visor Deluxe PDA Touch Screen Replacement, Outside cover and stylus: Schritt 1, Bild 2 von 2
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Touch Screen Replacement: Schritt 2, Bild 1 von 3 Handspring Visor Deluxe PDA Touch Screen Replacement: Schritt 2, Bild 2 von 3 Handspring Visor Deluxe PDA Touch Screen Replacement: Schritt 2, Bild 3 von 3
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Touch Screen Replacement: Schritt 3, Bild 1 von 3 Handspring Visor Deluxe PDA Touch Screen Replacement: Schritt 3, Bild 2 von 3 Handspring Visor Deluxe PDA Touch Screen Replacement: Schritt 3, Bild 3 von 3
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Touch Screen Replacement, Batteries: Schritt 4, Bild 1 von 2 Handspring Visor Deluxe PDA Touch Screen Replacement, Batteries: Schritt 4, Bild 2 von 2
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Touch Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Touch Screen Replacement, Back Cover: Schritt 6, Bild 1 von 1
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Touch Screen Replacement: Schritt 7, Bild 1 von 3 Handspring Visor Deluxe PDA Touch Screen Replacement: Schritt 7, Bild 2 von 3 Handspring Visor Deluxe PDA Touch Screen Replacement: Schritt 7, Bild 3 von 3
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Touch Screen Replacement: Schritt 8, Bild 1 von 3 Handspring Visor Deluxe PDA Touch Screen Replacement: Schritt 8, Bild 2 von 3 Handspring Visor Deluxe PDA Touch Screen Replacement: Schritt 8, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Disconnect the flex strip from the motherboard with tweezers.
  9. Handspring Visor Deluxe PDA Touch Screen Replacement, Touch Screen: Schritt 9, Bild 1 von 3 Handspring Visor Deluxe PDA Touch Screen Replacement, Touch Screen: Schritt 9, Bild 2 von 3 Handspring Visor Deluxe PDA Touch Screen Replacement, Touch Screen: Schritt 9, Bild 3 von 3
    • Release the latch in bottom right corner of the touchscreen.
    • Use the spudger (if needed) to pry the screen from the front case.
Abschluss
Cal Poly, Team 1-2, Regan SU 2012 Mitglied von Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 853
