Einleitung
The only tool needed is a #00 Phillips Screw driver.
Was du brauchst
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
Remove the four 2.6 mm Philips screws that are on the sides of the frame.
Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
