Zum Hauptinhalt wechseln
Handspring Visor Edge Button Board Replacement
Was du brauchst
  1. Handspring Visor Edge Button Board Replacement, Flip Cover: Schritt 1, Bild 1 von 2 Handspring Visor Edge Button Board Replacement, Flip Cover: Schritt 1, Bild 2 von 2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Button Board Replacement, Back Panel: Schritt 2, Bild 1 von 1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Button Board Replacement: Schritt 3, Bild 1 von 1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Button Board Replacement: Schritt 4, Bild 1 von 2 Handspring Visor Edge Button Board Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Button Board Replacement: Schritt 5, Bild 1 von 2 Handspring Visor Edge Button Board Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Button Board Replacement: Schritt 6, Bild 1 von 1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Button Board Replacement, Button Board: Schritt 7, Bild 1 von 1
    • Pull off front cover gently.
  8. Handspring Visor Edge Button Board Replacement: Schritt 8, Bild 1 von 1
    • Remove buttons by hand, they should come off easily.
Abschluss
Nick Lazarakis
331 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 11-28, Maness Winter 2011 Mitglied von Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 16
Insgesamt: 770
