Einleitung
In this guide, you will learn how to replace the screen on the Handspring Visor Edge PDA. You will need tweezers, a Phillips screwdriver, and a spudger to get under the screen.
Was du brauchst
Open the Visor Edge and place it on a table facing down.
Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
Remove the four 2.6 mm Philips screws that are on the sides of the frame.
Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
Flip over the PDA.
Use the tweezers to remove the ribbon cable attaching the screen to the circuit board.
Wedge the spudger in between the glass and the metal frame.
Slide the spudger down the length of the screen to detach from the frame.
With your hands, pry the screen up from the detached side. The screen will pop off.
