Einleitung
This guide will show you how to remove and replace a battery in the Hannspree SN12E2 laptop. Battery’s are used to power your device if your device is not turning on or holding a charge this may be the solution.
Unlatch the lock on the top right of your laptop first.
You will need to pull on the lock on the left side and remove the battery at the same time
The left lock is a spring lock and needs constant pressure applied in order to stay open.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
