Zum Hauptinhalt wechseln
Hannspree SN12E2 Fan/Motherboard Replacement
Was du brauchst
  1. Hannspree SN12E2 Fan/Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 3, Bild 1 von 3 Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 3, Bild 2 von 3 Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 Fan/Motherboard Replacement, Touchpad Plane/Keyboard: Schritt 4, Bild 1 von 1
    • Remove all the 5mm PH0 screws on the back cover
  5. Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 5, Bild 1 von 3 Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 5, Bild 2 von 3 Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Gently pry the case apart starting at the lower right corner using the small spudger
    • Move around the case gently prying until the touchpad plane is free from the rest of the case
  6. Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 6, Bild 1 von 2 Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Gently lift up on the touchpad portion of the touchpad plane
    • Unplug the ZIFF connector by pulling gently on the black retaining blade and removing the white flat flex cable
    • Pull the touchpad away from the rest of the case
  7. Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Gently lift up on the loose keyboard to expose the ZIFF connector.
    • Unplug the keyboard ZIFF following the same instructions as the touchpad ZIFF
  8. Hannspree SN12E2 Fan/Motherboard Replacement, Fan/Motherboard: Schritt 8, Bild 1 von 1
    • Remove 3.4mm PH0 retaining screws as well as the three 3mm PH0 fan screws
  9. Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 9, Bild 1 von 2 Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Unplug all pictured connectors
  10. Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 10, Bild 1 von 2 Hannspree SN12E2 Fan/Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove the motherboard from the housing place it on a flat surface.
    • Flip over the motherboard so that the heat pipes ae face up.and disconnect fan JST Connector, pictured in red
Abschluss
UMass Dartmouth, Team S2-G2, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S2-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G2
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 369
