Einleitung
Is your device loading files slowly or the files are corrupted? Use this guide to remove and replace the hard drive in your laptop.
Was du brauchst
Unlatch the lock on the top right of your laptop first.
You will need to pull on the lock on the left side and remove the battery at the same time
The left lock is a spring lock and needs constant pressure applied in order to stay open.
Next, lift up the hard drive and pull towards you. Lift up the end of the hard drive that is not plugged into the computer.
