Zum Hauptinhalt wechseln
Hannspree SN12E2 IO Board Replacement
Was du brauchst
  1. Hannspree SN12E2 IO Board Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 IO Board Replacement: Schritt 2, Bild 1 von 1
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 IO Board Replacement: Schritt 3, Bild 1 von 3 Hannspree SN12E2 IO Board Replacement: Schritt 3, Bild 2 von 3 Hannspree SN12E2 IO Board Replacement: Schritt 3, Bild 3 von 3
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 IO Board Replacement, Touchpad Plane/Keyboard: Schritt 4, Bild 1 von 1
    • Remove all the 5mm PH0 screws on the back cover
  5. Hannspree SN12E2 IO Board Replacement: Schritt 5, Bild 1 von 3 Hannspree SN12E2 IO Board Replacement: Schritt 5, Bild 2 von 3 Hannspree SN12E2 IO Board Replacement: Schritt 5, Bild 3 von 3
    • Gently pry the case apart starting at the lower right corner using the small spudger
    • Move around the case gently prying until the touchpad plane is free from the rest of the case
  6. Hannspree SN12E2 IO Board Replacement: Schritt 6, Bild 1 von 2 Hannspree SN12E2 IO Board Replacement: Schritt 6, Bild 2 von 2
    • Gently lift up on the touchpad portion of the touchpad plane
    • Unplug the ZIFF connector by pulling gently on the black retaining blade and removing the white flat flex cable
    • Pull the touchpad away from the rest of the case
  7. Hannspree SN12E2 IO Board Replacement: Schritt 7, Bild 1 von 1
    • Gently lift up on the loose keyboard to expose the ZIFF connector.
    • Unplug the keyboard ZIFF following the same instructions as the touchpad ZIFF
  8. Hannspree SN12E2 IO Board Replacement, Hard Drive Access Door: Schritt 8, Bild 1 von 1
    • Remove the three 3mm Phillips #0 screws.
  9. Hannspree SN12E2 IO Board Replacement: Schritt 9, Bild 1 von 1
    • Gently pull on the access panel to remove it.
  10. Hannspree SN12E2 IO Board Replacement, Hard Drive: Schritt 10, Bild 1 von 1
    • Remove the four 4mm Phillips #0 retaining screws.
    • The hard drive caddy is the large piece of metal with black circles.
  11. Hannspree SN12E2 IO Board Replacement: Schritt 11, Bild 1 von 1
    • Next, lift up the hard drive and pull towards you. Lift up the end of the hard drive that is not plugged into the computer.
  12. Hannspree SN12E2 IO Board Replacement: Schritt 12, Bild 1 von 2 Hannspree SN12E2 IO Board Replacement: Schritt 12, Bild 2 von 2
    • Slide your hard drive out of the metal piece by unscrewing the sides.
  13. Hannspree SN12E2 IO Board Replacement, IO Board: Schritt 13, Bild 1 von 1
    • Remove the three 3mm PH0 screws holding the IO board to the case.
  14. Hannspree SN12E2 IO Board Replacement: Schritt 14, Bild 1 von 3 Hannspree SN12E2 IO Board Replacement: Schritt 14, Bild 2 von 3 Hannspree SN12E2 IO Board Replacement: Schritt 14, Bild 3 von 3
    • Unplug the three JST connectors connecting the IO board to the motherboard.
    • For each connector, remove by gently pulling parallel to the connector housing until the connector becomes undone
    • When replacing the connectors ensure that they are oriented correctly. The housing is keyed to prevent the connectors from being plugged in backwards.
  15. Hannspree SN12E2 IO Board Replacement: Schritt 15, Bild 1 von 1
    • Remove IO Board by gently tilting it toward the outer edge of the case.
Abschluss
jacob
150 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S2-G2, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S2-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G2
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 121
