Einleitung
This guide will show you how to remove and replace the Speaker in the Hannspree SN12E2 laptop. Speakers are used to produce sound for your device if your device is not producing sound or if the sound is static or peaking this may be the solution.
Was du brauchst
Unlatch the lock on the top right of your laptop first.
You will need to pull on the lock on the left side and remove the battery at the same time
The left lock is a spring lock and needs constant pressure applied in order to stay open.
Gently pry the case apart starting at the lower right corner using the small spudger
Move around the case gently prying until the touchpad plane is free from the rest of the case
Gently lift up on the touchpad portion of the touchpad plane
Unplug the ZIFF connector by pulling gently on the black retaining blade and removing the white flat flex cable
Pull the touchpad away from the rest of the case
Gently lift up on the loose keyboard to expose the ZIFF connector.
Unplug the keyboard ZIFF following the same instructions as the touchpad ZIFF
