Zum Hauptinhalt wechseln
Hard / Factory Reset
Einführungsvideo
  1. Hard / Factory Reset, Hard Reset - Method One:: Schritt 1, Bild 1 von 3 Hard / Factory Reset, Hard Reset - Method One:: Schritt 1, Bild 2 von 3 Hard / Factory Reset, Hard Reset - Method One:: Schritt 1, Bild 3 von 3
    • Switch off the phone.
    • Pres the Power button and when you feel a vibration release it and press and hold the Volume Up button.
    • From Boot mode menu select [Recovery mode] (use Volume Up for navigation and volume doun for OK).
    • Now you are in the known Android System recovery menu. Use again the Volume Up for navigation and the Volume Down for OK and select one by one: wipe data/factory reset - Yes -- delete all user data - reboot system now.
    • Tis will reboot the device and will restore to its default settings.
  2. Hard / Factory Reset, Factory Reset - Method Two: Schritt 2, Bild 1 von 3 Hard / Factory Reset, Factory Reset - Method Two: Schritt 2, Bild 2 von 3 Hard / Factory Reset, Factory Reset - Method Two: Schritt 2, Bild 3 von 3
    • Press the Power button and wen you fill the vibration, release the Power button and press and hold the Volume Down button.
    • Now the device is in Factory mode. Use the Volume Up/Down buttons for movement and the Power button for OK and select Clear eMMC.
    • That's all. The phone will reboot and will be restored to a factory settings.
    • Did you do it successfully?
Abschluss
24 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.341 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.541 Anleitungen geschrieben
22 Kommentare
great simple clear instructions - did exactly what you said - phone back up and running good as new! Thanks. M
Marty - Antwort
Thanks. The phone has reset.
melandart - Antwort
“eMMC is busy can't format, please retry”
What do we do?
richterrea - Antwort
Today I also met this message. How did you solve this problem? Thanks, Zoltan (HUN)
Zoltán Bocskai -
HI!, I did the “clear eMMc” method but still my MePop_V03 phone still stock on logo screen.
what should I do?
Please help me .thanks in advance God bless
Herbert Redondo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 82
Letzte 30 Tage: 303
Insgesamt: 48,159
