Einleitung
The HP Pavilion dv4-1120us laptop uses an HDD 2.5 inches hard drive with a SATA interface. And can also be replaced for a solid state unit SSD with the same size and SATA port
Was du brauchst
Verify the laptop model. Remove the power cable.
The battery only requires to move a latch to the left. With this, it comes out by itself.
Remove the 2 screws. These are holding the plastic lid
Remove the three 5mm screws that hold the hard drive in place
Move the hard drive to the left to disconnect it from the SATA port
Lift the hard drive to remove it from the laptop
Remove the screws to put in the replacement
To reassemble your device, follow these instructions in reverse order
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
100%
Hier starten ›
