Einleitung
Replacing the hard drive on this device is quite easy as all of the components are accessible by removing a single cover.
Was du brauchst
First, turn off your laptop, then disconnect the power supply. Unplug any peripheral devices connected to your laptop.
Next, remove the battery from the laptop.
Next, remove the 4 Phillips screws from the service door cover (circled in red).
Remove the 4 screws circled in red in the photo.
Once the screws are removed, slide the hard drive to the right, with the help of the tab.
Remove the 4 screws located on the side of the support.
Then, remove the hard drive form its metallic support.
Finally, replace de hard drive with a new one or an SSD.
To reassemble your device, follow these steps in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
3 Kommentare
why do you do this?
You can do this to replace a faulty hard-drive or replace it by a SSD to get better performance. So I did this to replace mine by a new one and I wrote this guide for other people who search how to do it. As you can see, very easy to do.
Brendan -
Amazing tutorial, thanks :)
