Einleitung
If the LED lights do not function after troubleshooting, you might need to change the LED Board. For this replacement you need a Phillips #2 screw driver and a metal spudger.
Was du brauchst
Use a metal spudger to remove the top cover.
Use a Phillips #2 screwdriver to remove three 17 mm screws.
Grip larger cable connected to LED board and pull volume wheel until both are disconnected from the cable.
Pull lightly on the LED board to disconnect the smaller LED board cable from volume wheel.
