Einleitung
After completing the prerequisite guide for taking apart the front panel of the speaker, you can then access the battery and replace it when it is dying or not working.
Was du brauchst
Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
Remove the four wires connecting the front and back panels.
Pinch the connector tab and pull gently upwards.
Repeat for the other three connectors.
Begin by removing the three 10.4 mm T10 Torx screws from the battery cover.
Remove battery cover.
Pull battery out to replace.
45 weitere Nutzer:innen haben diese Anleitung absolviert.
21 Kommentare
Thanks for the step by step instructions. I have tried replacing the batteries but the speaker still won't turned on. I believe the battery cable/module is broken, do you know how to fix it? Thanks.
Can you put a step by step instruction how to replace a battery on a Harman/ Kardon esquire 2?
Can you tell me what kind of the hk onyx speaker battery's, if you can show me step instructions to replace! Thankyou!
