Einleitung
If you have looked at the troubleshooting page and identified that your issues with your Onyx Studio 2 are indeed due to the circuit board being bad, this guide will walk you through how to replace it.
Was du brauchst
Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
Remove the four wires connecting the front and back panels.
Pinch the connector tab and pull gently upwards.
Repeat for the other three connectors.
Pull the silicone button band off of the outer edge of the speaker.
Gently remove the control board band by placing fingers in contact with it through the button openings.
Disconnect the remaining connectors from the circuit board.
Disconnect the Bluetooth antenna.
Remove the four 10 mm T10 Torx screws.
Pull the circuit board out of the device as it is now free.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
Where do I get another one
Where we buy the board?
Umm… this was rather anticlimactic. Last step was basically like “and now contemplate your life choices”.
Where can I Buy a new hk onix studio Main board?
My speaker was working great. I just disconnected my phone to make a call, put YouTube back on it was all mumbled & the big button in the back kept pulsing so fast.
