Einleitung
There are no previous steps needed. All that is required is a #0 Phillips Screwdriver, (2) fresh AAA batteries, and a few minutes of time.
Was du brauchst
Unscrew the (2) #4 Phillips head 8 mm screws on the back cover using a Phillips #0 screwdriver. The screws are captured and do not need to be completely removed from the back cover.
The batteries are now accessible. Remove batteries using fingers or plastic spudger.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
