Zum Hauptinhalt wechseln
Hasbro Bop-It Micro Series Buttons Replacement
Was du brauchst
  1. Hasbro Bop-It Micro Series Buttons Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Buttons Replacement: Schritt 2, Bild 1 von 1
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Buttons Replacement: Schritt 3, Bild 1 von 1
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Buttons Replacement, Buttons: Schritt 4, Bild 1 von 1
    • Remove the buttons by de-soldering them from the wires they are attached to or from the mother board. Refer to the soldering guide here.
  5. Hasbro Bop-It Micro Series Buttons Replacement: Schritt 5, Bild 1 von 1
    • After removing the buttons, solder new, operational buttons back into place.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Glenn Haag
479 Reputation
3 Anleitungen geschrieben
IUPUI, Team 3-1, Harley Fall 2016 Mitglied von IUPUI, Team 3-1, Harley Fall 2016
IUPUI-HARLEY-F16S3G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 25
Insgesamt: 1,905
