Einleitung
This guide will lead you through how to replace the batteries in your Hasbro Iron Man Infinity Nano Gauntlet. If your gauntlet is not working, the batteries may be dead or damaged. Replacing the batteries may fix the issue.
Find the removable panel at the bottom of the hand.
Use your finger to push upwards and open the panel.
Slide the panel off and separate it from the hand.
Remove the left-most battery by pushing down on the positive end and pulling it out.
Repeat this for the next two batteries.
