Einleitung
The Hasbro Iron Man Infinity Nano Gauntlet is not much without its radiant gems. If the LED lights within your gauntlet are faulty, here is an effective way to fix them.
Was du brauchst
Find the removable panel at the bottom of the hand.
Use your finger to push upwards and open the panel.
Slide the panel off and separate it from the hand.
Remove the left-most battery by pushing down on the positive end and pulling it out.
Repeat this for the next two batteries.
Open the gauntlet carefully, as there are wires connecting both sides.
Address which LED is faulty. Check if the wires connecting to it are all intact; If there is a detachment within the circuits, reconnect it to its location. The LED should operate in that instance.
Reconnect it to its respective surface and check if it fits with in the magnetic gem. If not, consider another replacement.
