Was du brauchst
Use a #0 Phillips head screwdriver and unscrew the sixteen 7mm screws on the back of the device.
To take out the CPU fan it is necessary to disconnect the CPU fan cable. Use a plastic opening tool to remove the cable.
Use a #0 Phillips head screwdriver to remove the two 7mm screws holding the fan to the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
