Was du brauchst
Use a #0 Phillips head screwdriver and unscrew the sixteen 7mm screws on the back of the device.
To take out the Graphics card fan it is necessary to disconnect the two Graphic card fan cables. Use a plastic opening tool to remove the cable.
Use a #0 Phillips head screwdriver and unscrew the five 7mm screws holding the fan in place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
