Was du brauchst
Remove the stickers covering the screws. These are located on both corners of the screen. (Two in total)
Remove the two 7mm screws.
Use a plastic opening tool to pull the plastic screen bezel forward.
Remove the 4 7mm screws in the corners holding the screen up.
Use a plastic oping tool to pry the screen forward. Lay it on the keyboard.
Peel off the tape that connects the chord to the screen.
Carefully unplug chord.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
