Zum Hauptinhalt wechseln
Haute42 S13 Button and Switch Replacement
Was du brauchst
  1. Haute42 S13 Button and Switch Replacement, Button Switch: Schritt 1, Bild 1 von 1
    • Unplug the controller from any device it is connected to and make sure it is powered off.
  2. Haute42 S13 Button and Switch Replacement: Schritt 2, Bild 1 von 3 Haute42 S13 Button and Switch Replacement: Schritt 2, Bild 2 von 3 Haute42 S13 Button and Switch Replacement: Schritt 2, Bild 3 von 3
    • Use a keycap puller to remove the keycap from its socket.
    • Avoid using excessive force to prevent damaging the device.
  3. Haute42 S13 Button and Switch Replacement: Schritt 3, Bild 1 von 3 Haute42 S13 Button and Switch Replacement: Schritt 3, Bild 2 von 3 Haute42 S13 Button and Switch Replacement: Schritt 3, Bild 3 von 3
    • Use the keycap/switch puller to remove the switch from its socket.
    • Be careful not to damage the controller while removing the switch.
  4. Haute42 S13 Button and Switch Replacement: Schritt 4, Bild 1 von 2 Haute42 S13 Button and Switch Replacement: Schritt 4, Bild 2 von 2
    • Align the pins of the new switch with the holes in the socket and replace the switch.
    • You will feel the pins slide into place.
    • Do not press the switch in until you know you have aligned it correctly, doing so may damage the pins on the switch.
  5. Haute42 S13 Button and Switch Replacement: Schritt 5, Bild 1 von 1
    • Use your finger to push the switch into place.
    • You should hear a click when it connects.
    • Try moving it to make sure it is firmly in place. It should not move at all when attached to the controller.
  6. Haute42 S13 Button and Switch Replacement: Schritt 6, Bild 1 von 3 Haute42 S13 Button and Switch Replacement: Schritt 6, Bild 2 von 3 Haute42 S13 Button and Switch Replacement: Schritt 6, Bild 3 von 3
    • Align the cross on the keycap and the cross on the switch and gently press the keycap onto the switch.
    • Avoid applying excessive pressure to prevent damaging the new switch.
  7. Haute42 S13 Button and Switch Replacement: Schritt 7, Bild 1 von 1
    • Take a look at the OLED input display on the controller while pressing it to check if the button is fully functional.
    • On the screen, the button should highlight itself and the input history should be displayed at the bottom. If it all works, congratulations! You have successfully replaced this button.
Ziellinie
3 weitere Personen haben diese Anleitung absolviert.
York University, Team 3-2, Woodhouse Winter 2025 Mitglied von York University, Team 3-2, Woodhouse Winter 2025
YORK-WOODHOUSE-W25S3G2
2 Mitglieder
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 31
Letzte 30 Tage: 134
Insgesamt: 1,628
