Zum Hauptinhalt wechseln
Havoc Heli IR LED Replacement
Was du brauchst
  1. Havoc Heli IR LED  Replacement, Havoc Heli IR LED: Schritt 1, Bild 1 von 2 Havoc Heli IR LED  Replacement, Havoc Heli IR LED: Schritt 1, Bild 2 von 2
    • Power off the controller before disassembly.
    • Place a small piece of tape over the Light button to prevent it from falling out in later steps.
    • Flip the controller over so the back is facing up.
  2. Havoc Heli IR LED  Replacement: Schritt 2, Bild 1 von 3 Havoc Heli IR LED  Replacement: Schritt 2, Bild 2 von 3 Havoc Heli IR LED  Replacement: Schritt 2, Bild 3 von 3
    • Remove the battery compartment screw with a small Phillips screw driver.
    • Lift off the battery cover.
    • Remove the six AA batteries from the compartment.
  3. Havoc Heli IR LED  Replacement: Schritt 3, Bild 1 von 3 Havoc Heli IR LED  Replacement: Schritt 3, Bild 2 von 3 Havoc Heli IR LED  Replacement: Schritt 3, Bild 3 von 3
    • Remove the remaining four screws with a small Phillips screw driver.
    • Flip the device over so the front is facing up.
    • Remove the front cover and place it to the left side.
    • Make sure to note the locations of the joysticks and other controls in case they fall out of place during this or future steps.
  4. Havoc Heli IR LED  Replacement: Schritt 4, Bild 1 von 1
    • Lift up the red IR LED cover to remove it.
  5. Havoc Heli IR LED  Replacement: Schritt 5, Bild 1 von 2 Havoc Heli IR LED  Replacement: Schritt 5, Bild 2 von 2
    • Use the soldering iron and solder wick to remove the solder from the IR LED you're replacing.
    • Pull the LED out through the top.
  6. Havoc Heli IR LED  Replacement: Schritt 6, Bild 1 von 2 Havoc Heli IR LED  Replacement: Schritt 6, Bild 2 von 2
    • Insert the new LED into the slot.
    • Make sure that the short lead of the LED is on the right.
    • Use the soldering iron and solder to connect the new LED.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Michael Kent
128 Reputation
1 Anleitung geschrieben
Michigan Tech, Team 1-13, Lauer Fall 2016 Mitglied von Michigan Tech, Team 1-13, Lauer Fall 2016
MTU-LAUER-F16S1G13
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 22
Insgesamt: 543
