Einleitung
This is a quick, super simple replacement that can be done in the lot of the auto parts store. Good luck!
Was du brauchst
Before you begin, make sure you have the right bulb. I got this at the local autozone.
Vinyl or latex gloves are great if you have them available, but not required.
Press firmly on the plugs clip and pull to remove the power cable from the bulb.
Remove the bulb by pulling it away from the headlight enclosure.
Once the old bulb is removed, take your new one and place it in the headlight.
Follow the steps in reverse to secure the new bulb in the headlight.
To replace the bulb, follow the steps in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
