Zum Hauptinhalt wechseln
Headlight Bulb Replacement
Was du brauchst
  1. Headlight Bulb Replacement, Headlight Bulb: Schritt 1, Bild 1 von 1
    • Before you begin, make sure you have the right bulb. I got this at the local autozone.
    • Do NOT touch the glass of the bulb. The oils from your fingers can drastically reduce the life of the bulb.
    • Vinyl or latex gloves are great if you have them available, but not required.
  2. Headlight Bulb Replacement: Schritt 2, Bild 1 von 2 Headlight Bulb Replacement: Schritt 2, Bild 2 von 2
    • Press firmly on the plugs clip and pull to remove the power cable from the bulb.
  3. Headlight Bulb Replacement: Schritt 3, Bild 1 von 3 Headlight Bulb Replacement: Schritt 3, Bild 2 von 3 Headlight Bulb Replacement: Schritt 3, Bild 3 von 3
    • Lift up and remove the metal wire cage holding the bulb in place.
  4. Headlight Bulb Replacement: Schritt 4, Bild 1 von 1
    • Remove the bulb by pulling it away from the headlight enclosure.
    • Once the old bulb is removed, take your new one and place it in the headlight.
    • Follow the steps in reverse to secure the new bulb in the headlight.
Abschluss
To replace the bulb, follow the steps in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Tim Asp
3.905 Reputation
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 3,434
