Einleitung
The headphone jack is located on the side of the laptop. This guide will take you through the procedure on how to remove the headphone jack from your laptop in case there is any audio issues such as sound/mic/line in not working and how to remove the headphone jack for replacement.
  1. Unplug laptop  from adapter and all other devices.
    • Unplug laptop from adapter and all other devices.
  2. Flip the laptop over with battery facing you.
    • Flip the laptop over with battery facing you.
  3. Slide the battery lock on the right side open. Slide the Battery release latch on the left side.
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. Pull battery out.
    • Pull battery out.
  5. Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  7. Push screwdriver through screw hole top  pop the keyboard.
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  8. Pry up the keyboard.
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  9. Remove keyboard  wire  by popping latch under blue  plastic
    • Remove keyboard wire by popping latch under blue plastic
  10. Using the spudger to lift up on the white  tabs
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  11. Remove the five 5.5mm Phillips #1 screws from the case
    • Remove the five 5.5mm Phillips #1 screws from the case
  12. Remove eight 6.5mm Phillips #1 screws from the back cover
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  13. Starting at a top corner, use the pry tool to split the case. Slowly work around the case, pulling up gently to release the clips. Slowly work around the case, pulling up gently to release the clips.
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  14. Use the spudger to lift the white tab
    • Use the spudger to lift the white tab
    • pull horizontally on the blue ribbon to disconnect the cable
  15. Use plastic pry tool to lift up on headphone jack assembly
    • Use plastic pry tool to lift up on headphone jack assembly
Abschluss
Tyler Lirio
93 Reputation
1 Anleitung geschrieben
USF Tampa, Team S11-G2, Cheng Spring 2018 Mitglied von USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 53
