Einleitung
The headphone jack is located on the side of the laptop. This guide will take you through the procedure on how to remove the headphone jack from your laptop in case there is any audio issues such as sound/mic/line in not working and how to remove the headphone jack for replacement.
Was du brauchst
Slide the battery lock on the right side open.
Slide the Battery release latch on the left side.
Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
Using the spudger to lift up on the white tabs
Pull horizontally on the blue ribbon to disconnect the cables
Starting at a top corner, use the pry tool to split the case.
Slowly work around the case, pulling up gently to release the clips.
Use the spudger to lift the white tab
pull horizontally on the blue ribbon to disconnect the cable
