Zum Hauptinhalt wechseln
Health o Meter HDR743 Power Supply Replacement
Was du brauchst
  1. Health o Meter HDR743  Power Supply Replacement, Power Supply: Schritt 1, Bild 1 von 1
    • Connect a voltmeter at the power supply’s connection to the circuit board and the power supply.
    • If the the voltage at the power supply is incorrect, the power supply should be replaced.
  2. Health o Meter HDR743  Power Supply Replacement: Schritt 2, Bild 1 von 1
    • Use wire strippers to cut the wired connection to the power supply.
    • If the wires need replacing, you will need to use a soldering iron and remove the connections at the board.
  3. Health o Meter HDR743  Power Supply Replacement: Schritt 3, Bild 1 von 1
    • Use the wire strippers to cut off the rubber ends of the power supply wires.
    • Use a soldering iron and solder to fuse the connections between the two wires.
  4. Health o Meter HDR743  Power Supply Replacement: Schritt 4, Bild 1 von 2 Health o Meter HDR743  Power Supply Replacement: Schritt 4, Bild 2 von 2
    • Test the power supply once the wires have been reconnected.
    • If the Health o Meter still has power issues, check the connections between the new power supply and the board.
    • If no issues are found, the circuit board may need to be replaced.
Abschluss
Dennis White Jr
217 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 117
