Zum Hauptinhalt wechseln
Health o Meter HDR743 Wire Connection Replacement
Was du brauchst
  1. Health o Meter HDR743 Wire Connection Replacement, Wire Connection: Schritt 1, Bild 1 von 1
    • Use a voltmeter to check for power in the wires.
    • If the power is on, the voltmeter will give a reading. Verify if the red indicator light is visible.
  2. Health o Meter HDR743 Wire Connection Replacement: Schritt 2, Bild 1 von 1
    • Identify where the issue in the wire begins.
    • If the problem isn't near a connection, use wire strippers to cut away the troubled area, and splice a new wire in-between.
    • If the troubled area cannot be found, the entire wire will need to be replaced.
    • Use a soldering iron to remove the wire from its connection to the circuit board.
    • Use wire strippers to remove the wires from the other components.
  3. Health o Meter HDR743 Wire Connection Replacement: Schritt 3, Bild 1 von 1
    • Use a soldering iron to solder and splice a new wire to the component.
    • The other end of the wire should be spliced or soldered directly to the circuit board.
  4. Health o Meter HDR743 Wire Connection Replacement: Schritt 4, Bild 1 von 1
    • Test the new connection with the voltmeter.
    • If the issue persists, the repair has failed, or a different component is faulty.
Abschluss
Dennis White Jr
217 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 114
