Zum Hauptinhalt wechseln
Heyday Round Bluetooth Speaker Motherboard Replacement
Was du brauchst
  1. Heyday Round Bluetooth Speaker Motherboard Replacement, Heyday Round Bluetooth Speaker Disassembly: Schritt 1, Bild 1 von 2 Heyday Round Bluetooth Speaker Motherboard Replacement, Heyday Round Bluetooth Speaker Disassembly: Schritt 1, Bild 2 von 2
    • Use a metal spudger to pry the fabric-covered top off of the speaker.
  2. Heyday Round Bluetooth Speaker Motherboard Replacement: Schritt 2, Bild 1 von 3 Heyday Round Bluetooth Speaker Motherboard Replacement: Schritt 2, Bild 2 von 3 Heyday Round Bluetooth Speaker Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
    • Remove the inner shell from the back case.
    • Don't yank or pull the shell case off the bottom case. There are cables connecting the two and they could be damaged if pulled.
  3. Heyday Round Bluetooth Speaker Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the two screws holding the motherboard in place.
  4. Heyday Round Bluetooth Speaker Motherboard Replacement: Schritt 4, Bild 1 von 2 Heyday Round Bluetooth Speaker Motherboard Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a pair of tweezers to disconnect the yellow wire from the motherboard by pinching the input and pulling away from the motherboard.
  5. Heyday Round Bluetooth Speaker Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Carefully remove the motherboard by sliding it upwards.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
I have a Harman kardon onyx studio 5 speaker and it stop working, so I open it and discover the motherboard bent.I don't know where else to get it. Kindly help me out. My email is johnsonajen@gmail.com thanks🙏
Ajen Johnson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 21
Insgesamt: 333
