Was du brauchst
Use a metal spudger to pry the fabric-covered top off of the speaker.
Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
Remove the inner shell from the back case.
Use a Phillips #0 screwdriver to remove the two screws holding the motherboard in place.
Use a pair of tweezers to disconnect the yellow wire from the motherboard by pinching the input and pulling away from the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
I have a Harman kardon onyx studio 5 speaker and it stop working, so I open it and discover the motherboard bent.I don't know where else to get it. Kindly help me out. My email is johnsonajen@gmail.com thanks🙏
