Was du brauchst
Use a metal spudger to pry the fabric-covered top off of the speaker.
Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
Remove the inner shell from the back case.
Use curved tip tweezers to detach the connectors of two 2-prong Aux In/Out plugs extending from the subwoofer.
Use a Phillips #0 screwdriver to remove the four screws at the edge of each subwoofer to release them.
Remove both subwoofers.
