Einleitung
After years of service your battery may be weak or no longer hold a charge. This guide replaces your battery with a new one.
Was du brauchst
Disconnect the wires that connect the battery to the motherboard using the spudger.
Slide the spudger underneath the battery and gently lift it off of the adhesive.
Place the new battery in the same location and connect the wires the same way as the previous battery.
Fast fertig!
Abschluss
