Einleitung
Users must disassemble the front cover to replace the battery. A replacement battery will be needed. This is a difficult process for users who do not have experience with soldering connections.
Was du brauchst
Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
Insert the plastic opening tool between the screen cover and rear cover of the tablet.
Grasp the small suction cup.
Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
Pull upward on the small suction cup handle while sliding the opening tool.
Remove the black placement tape from the battery.
Find the two battery solder connections on the circuit board.
Remove the red and black battery wires from the circuit board with the solder removal tool.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
