Zum Hauptinhalt wechseln
Hipstreet Titan 2 HD Rear Case Replacement
Was du brauchst
  1. Hipstreet Titan 2 HD Rear Case Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
    • The screws are located on the bottom face of the device, near the power and volume controls.
  2. Hipstreet Titan 2 HD Rear Case Replacement: Schritt 2, Bild 1 von 1
    • Place the small suction cup on your screen.
    • Moisturize the bottom of the suction cup to ensure a proper seal.
    • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
  3. Hipstreet Titan 2 HD Rear Case Replacement: Schritt 3, Bild 1 von 1
    • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
    • Grasp the small suction cup.
  4. Hipstreet Titan 2 HD Rear Case Replacement: Schritt 4, Bild 1 von 2 Hipstreet Titan 2 HD Rear Case Replacement: Schritt 4, Bild 2 von 2
    • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
    • Pull upward on the small suction cup handle while sliding the opening tool.
    • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
  5. Hipstreet Titan 2 HD Rear Case Replacement: Schritt 5, Bild 1 von 2 Hipstreet Titan 2 HD Rear Case Replacement: Schritt 5, Bild 2 von 2
    • Use the plastic opening tool to remove the speaker from the rear cover.
    • The speaker is held in place with adhesive and is easily removed.
    • Do not pull on the speaker wires. This could damage the soldering connections.
  6. Hipstreet Titan 2 HD Rear Case Replacement: Schritt 6, Bild 1 von 1
    • Once the speaker is disconnected, the cover removal is complete.
Abschluss
Congratulations your tear down is complete. To reassemble your device, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jeffrey
766 Reputation
5 Anleitungen geschrieben
Colorado Springs, Team 5-6, Panko Spring 2015 Mitglied von Colorado Springs, Team 5-6, Panko Spring 2015
UCCS-PANKO-S15S5G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 602
